Nozzle Dimension, Tube Length Standard
Posted 29 April 2010 - 12:42 PM
I'm need of "nozzle dimension, tube length standard," for my HE design? Where could I find them? How could I calculate the pressure and temperature design from the operating condition?
Thank you.
Posted 29 April 2010 - 02:53 PM
I believe that google could do ...it is in national codes & standards ...by the way - TASC has built in data base of standard pipe diameters and thicknesses ...all you have to do is to specify nominal diameter and schedule of your nozzle...Hello
Thank you.
Posted 30 April 2010 - 10:09 AM
Hello
Thank you.
I think TEMA would be helpful about first part of your query.
About your second query for specifying the design pressure/temperature you should refer to relevant "process sizing criteria".In this document of project you will find the values should be added to operating values in your case leaded to specifying design values.
Posted 30 April 2010 - 10:20 AM
Could anyone explain these Warnings? What should I do to solve them?
1. *** WARNING *** A high fraction (0.8196) of the duty in a condenser is due to
condensate subcooling. Prediction of condensate subcooling heat transfer can be
less certain than condensation heat transfer.
End of Review of Thermal Calculations
Edited by eastorca, 30 April 2010 - 08:45 PM.
Posted 30 April 2010 - 10:25 AM
Hello
Thank you.
Thank you. Did you mean the book: TEMA 9TH EDITION?. For the book "Process sizing criteria" I'll try to find right now.
Posted 07 May 2010 - 02:44 AM
i hope i wont be too late to join this enquiry as some weeks before my life is really hectic.
for your first query - nozzle dimension, usually you can ask your engineers for pipe schedule sheet as supplier usually will provide us for our reference. if you are HTRI user, you can find the dimension from nozzle schedule.
second query, regarding the design pressure and design temp, i will recommend you to refer API 661 for calculation. even API 661 is for air cooler, i will use their DP and DT calculation as it is also for pressurized material.
Thanks.
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Shell And Tube Heat Exchanger In HtriStarted by Guest_Sanjayr126_* , 28 Sep 2021 |
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
