process /I&C field can help.
interlock is to prevent accidental opening of circulation loop drains of V-67251
When the following conditions is happened,
XV-400 opened (holding vessel bottom valve)
XV-431 opened or XV-435 opened or XV-432 opened or XV-434 opened or
XV-436 opened
P-67251 running (holding vessel circulation pump)
the Action of following will start
XV-402 can not open (nitrogen to circulation loop at bottom of holding vessel)
XV-422 can not open (ODR, organic drain waste)
XV-423 can not open (EDR, aqueous drain waste)
My question is very sample.Why the orgainc waste drain valve and aqueous drain valve will
be closed as if the P-67251 is running.
Thank you very much for your kindly help.
