Could anyone explain what is back flashing facility for heat exchanger?
I've got such comment that must to answer: "Back flushing facility shall be provided for W-2106".
W-2106 is a vapours condenser cooled with water in tube side.
Thanks in advance for replies.
Back Flushing Facility
Started by wojtar, Jun 16 2010 09:15 AM
Posted 16 June 2010 - 09:15 AM
Posted 16 June 2010 - 11:31 PM
Dear Wojtar-
Firstly, I guess, it is not "back flashing", but "back flushing", what is expected. Please confirm.
It it is so, it is generally related to cooling water, as this is fouling liquid. As you know that performance of heat exchanger is adversly affacted due to fouling. One way is to have periodical mechanical cleaning of tubes (cooling water is generally on tube side). However, this requires shut down of the heat exchanger (in many cases, it is shut down of entire plant).
This periodical cleaning can be prolonged by doing "back flushing". In this, cooling water supply valve is closed, water is allowed to drain from drain valve which is at the upstream of cooling water supply isolation valve near exchanger. Thus, C.W. flows from return header to heat exchanger to drain.
This back flushing causes any suspended particle fouled over tube wall to come out in drain & hence improvement in the performance. However, during this operation, plant load needs to be lowered down, so that process should not get distrubed.
Hope, this has clarified the matter.
Posted 17 June 2010 - 01:52 AM
Thanks a lot. It seems that it's clear. However, all described above is possible on my installation. Statement "back flushing facility" suggested something more sophisticated.
Back Pressure Of Elevated Flare Vs Ground FlareStarted by Guest_Sid__* , 04 Jan 2024 |
Back Pressure In FiltersStarted by Guest_panagiotis_* , 22 Jan 2024 |
Bringing Back Sponge Absorber To Service EvaluationStarted by Guest_mje03_* , 30 Oct 2023 |
Flare Back Pressure Estimation At Basic DesignStarted by Guest_Mahdi Malek Alaie_* , 10 Apr 2023 |
Process Facility CostingStarted by Guest_BabRafiq1_* , 23 Mar 2023 |
