Sir
I am having a closed loop cooling water pump, with a rated capacity of 600 m3/hr at 5.7 bar and maximum operating tempearture of 49 deg C.
Below is the analysis of the water:
Iron as Fe <0.5
Aluminium as Al <1.0
Copper as Cu <0.1
Silica as SiO2 <150
Manganese as Mn <0.5
Oil and Grease <5.0
Ammonia as NH3 <0.2
Calcium as CaCO3 <500
Magnesium as CaCO3 <200
Phosphate as PO4* <0.2*
Chromate as CrO4 <0.005
Chloride as Cl <50
Sulphate as SO4 <50
Zinc as Zn* <0.05*
Total Suspended Solids as TSS <10
Total Organic Carbon as C <5
Free Chlorine as Cl2 <1.5
Fluoride as F <0.05
Conductance as *Siemens/cm** <2000
Based on this, I have selected a cast iron-casing and a bronze impeller. Is it okay? Design life required is 20 years.
Vinod
Cooling Water Pump-Moc
Started by vinod, Jun 17 2010 09:33 AM
No replies to this topic
Posted 17 June 2010 - 09:33 AM
Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
Solid Naoh Dissolving In WaterStarted by Guest_lak1r_* , 10 Apr 2023 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Turbine Driven PumpStarted by Guest_Rahimzadeh_* , 27 Apr 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
