Hi
I m trying to size an ejector with low pressure steam as motive to compress moist air from 0.40 bara to 0.48 bara.
Can you suggest a resource which can help me with this task?
Thanks very much,
Prakash
Sizing An Jet Ejector
Started by gprakashn, Jul 12 2010 01:32 PM
Posted 12 July 2010 - 01:32 PM
Posted 13 July 2010 - 10:20 AM
gprakashn,
If your intention is to buy a steam jet ejector then I would suggest you not to take up this exercise since ejector design still involves a lot of art then just plain engineering. There are specialist vendors who would supply you the right ejector. Some of the vendors are:
Graham Mfg. Co.
Croll Reynolds
GEA Jet Pumps
Schutte & Koerting
If this is just a plain academic exercise then I suggest you refer Ludwig's "Applied Process Design for Chemical & Petrochemical Plants" for some very good guidelines on ejector design.
Graham Mfg. Co.
Croll Reynolds
GEA Jet Pumps
Schutte & Koerting
Posted 03 June 2011 - 12:18 PM
Hey guys when i googled steam eductor, i got ejector and injector. Then I go steam jet ejector and steam jet vacuum ejector/eductor/pump
what is the difference or is that a combination of all the ejector and pump together for both steam and vacuum? Help!
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
