Sizing Of Hydrocyclone Vessel
15 replies to this topic
#1 Phani Kanth
Phani Kanth
  • 19 posts
Posted 24 September 2010 - 07:31 AM
Please suggest how to size Hydrocyclone vessel for Produced Water Treatment Package for given inlet produced water operating conditions and analysis from production separator
Phani Kanth
  • 6,747 posts
Posted 24 September 2010 - 10:49 AM
Can you reformulate your query with additional info and may be a sketch
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 24 September 2010 - 03:02 PM
Here's additional info: it gives very clear guidelines, requirements, and performance limitations of a Hydrocyclone.
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 24 September 2010 - 11:27 PM
Phani,
Some additional information on hydrocyclones is attached.
Ankur
#5 Phani Kanth
Phani Kanth
  • 19 posts
Posted 27 September 2010 - 07:41 AM
Dear Breizh,
Thank you for your reply and interest regarding this tag.
I'm here attached Process Data Sheet for entire system(Produced Water Treatment) and i hope this will more describe detailed info.
Phani.
Edited by Phani Kanth, 27 September 2010 - 07:44 AM.
#6 Phani Kanth
Phani Kanth
  • 19 posts
Posted 27 September 2010 - 07:50 AM
See if attached file is of any help (in microsoft XPS format).
Sachin
Thank you Sachin for your reply and information.
Please suggest how to simulate this liquid liquid Hydro cyclone in Hysys
Phani.
#7 Phani Kanth
Phani Kanth
  • 19 posts
Posted 27 September 2010 - 07:52 AM
Thank you Mr.Zauberberg for your valuable information.
Please suggest how to simulate this Hydro Cyclone in Hysys.
Phani.
#8 Phani Kanth
Phani Kanth
  • 19 posts
Posted 27 September 2010 - 07:55 AM
Phani,
Ankur
Thank you Mr.Ankur for your valuable information.
Please suggest how to simulate this Liquid Liquid Hydro cyclone in Hysys.
Phani.
#9 Zauberberg
Zauberberg
  • 2,728 posts
Posted 27 September 2010 - 02:33 PM
You can use 3-phase separator, with dummy vapor stream attached to the vessel. Then, by using Carry Over parameters in the Vessel Window, you can adjust the amount of each liquid phase entrained into the other liquid phase.
#10 Dr.Process
Dr.Process
  • 5 posts
Posted 13 July 2011 - 04:16 AM
Any of you have the excel spreadsheet for sizing a multi liners hydrocyclone for produced water treatment?
#11 Chem_Met
Chem_Met
Posted 18 July 2011 - 04:00 PM
Do you have excel spreadsheet for sizing a multi liners hydrocyclone?
Sachin
My 2c
#12 Ariel
Ariel
  • 49 posts
Posted 06 August 2015 - 10:33 AM
Hi everybody!
I have a question about de use of some parameter of cyclone.xls spreadsheet.
When I want to calculate the dimensions of the cyclone, there are some parameters that are used depending on the type of cyclone ( Stairmand , Swift , Peterson - Whitby ) linking all equipment dimensions with the inlet diameter of the cyclone. It is correct to use these parameters to calculate a cyclone for separating sand from gas operating at high pressure (100 bar) ?
Another question: The inlet area is calculated from a suggested speed of 15 to 30 m/s. (50/100 f/s on the spredsheet). If you applied this recommended speed, small diameter are obtained. Do you knows if this recommendation is valid for high operation pressure (100bar)?
Thanks!!!!
Ariel
#13 Bobby Strain
Posted 06 August 2015 - 11:47 AM
Never attempt to design such equipment. Give conditions to the manufacturer and let them provide a properly designed unit.
#14 Ariel
Ariel
  • 49 posts
Posted 06 August 2015 - 12:30 PM
Thanks Bobby,
Unfortunately is exactly want we want to do. We are a company that manufacture equipment for oil and gas industry (separators, piping on skid, vessels, manifolds, etc). Now, there“s an Oil company that decide to give us the opportunity to build a solid-gas cyclone separator to make an experimental test on a non-conventional well.
Thanks again.
Ariel
#15 Bobby Strain
Posted 06 August 2015 - 12:54 PM
Good luck. Sometimes there are opportunities that we should refer to others. I have been in the same position as yourself. Our company leaders sometimes make promises that we can't deliver.
#16 thorium90
thorium90
  • 1,073 posts
Posted 07 August 2015 - 11:46 AM
Might be a good idea for your company to invest in some CFD software. I have seen many manufacturers of cyclones display their CFD results on sales talks.
