I am looking for information on noise requirements for elevated flares. I am aware that noise can be a big issue in flare design, but can't find any specific noise requirements that flares need to comply with. Can someone point me in the right direction please?
Thank you!
Flare Noise
Started by areads, Oct 21 2010 10:13 AM
Posted 21 October 2010 - 10:13 AM
Posted 21 October 2010 - 11:25 AM
areads,
Maximum acceptable noise level for any continuously noise generating equipment is 85 dBA considering human health hazard.
For elevated flares the distance and location beyond which noise level of 85 dBA should not be exceeded is defined by API STD 537 as follows:
Hope this helps.
Unless otherwise specified, noise at the base of the flare is defined at a point 1.5m (5 ft) above grade and 10% of the flare stack height distance from the flare stack centerline.
Hope this helps.
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
Flare And Venting SystemStarted by Guest_miz19_* , 10 Jul 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
