Edited by melake daniel, 14 December 2010 - 09:41 AM.
Atmospheric Distillation Unit
Started by melake daniel, Dec 14 2010 09:40 AM
Posted 14 December 2010 - 09:40 AM
Atmospheric distillation units are mainly used in refineries for the separation of the crude oil in to different light fractions like gas, LPG, gasoline, naphtha and heavy atmospheris residue then what is the general mass and energy balance for most ADU?
Posted 14 December 2010 - 10:10 AM
Crude Assay is the document which tells you how much of each fraction (i.e. C2-, LPG, Naphtha, Kerosene, Gas Oil, and Light Residue) is contained in any of the particular Crude oil, depending on its origin. Crude assay provides an exhaustive information required for design of CDU (ADU/VDU), and it also gives you the information about basic material balance.
http://www.totsa.com...ssays.php?rub=1
http://www.exxonmobi..._oil/index.html
http://www.bp.com/pr...ntentId=7020300
http://www.statoil.c...es/default.aspx
As for the energy balance (internal + utilities), the best approach would be to obtain actual plant data from some of the refineries around. If that is not possible, try Google-ing around as there is a lot of information available. For example, see the example for several units in this paper, pages 18 onwards:
http://ies.lbl.gov/i...mrefineries.pdf
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , Today, 03:06 AM |
Gas Blanketing Vent Size For Atmospheric Storage TankStarted by Guest_Fergie_* , 13 Apr 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
