Dear All
Anyone has information or knows where to find material compatability data
to hold aqueous Dimethylamine (around 30%w/w) and anhydrous Dimethylamine for temperature
of around 150-300oF?
I have look at a book called "Corrosion Resistance Tables" by Schweitzer.
It stated that Hastelloys, SS304 and SS316 are not suitable to hold either
aqueous or anhydrous DMA at any temperature.
I'm looking for a second source to confirm it but seems most sources don't have data for dimethylamine.
thanks
cch
Material Compatability For Dma
Started by Guest_Macca Chiu_*, May 05 2005 07:58 AM
#1 Guest_Macca Chiu_*
Posted 05 May 2005 - 07:58 AM
Posted 06 May 2005 - 01:59 AM
The best way to be certain that you are employing the optimum material of construction with DMA is to follow your company's published recommendations - usually found in your company's piping code or standards. This is, of course, assuming that your company has a code.
In the event your company has no standards for their materials of construction, then go immediately to the other "experts": the manufacturers of DMA. These would be Huntsman, Dow, and others around my neck of the woods (the Texas Gulf Coast). The manufacturers know exactly what you can use safely and what is not recommended as material of construction - for the pure compound as well as for solutions. They will be elated to share this information with you in order to cultivate you as a customer of their product. Normally, MSDS information does not include good and specific M.O.C. information.
If you are going to use the M.O.C. recommendation for specifying actual equipment, then do not depend or rely on information obtained through an internet forum. Employ the manufacturer's recommendation or that of a paid, recognized, expert engineering consultant.
If you are a student using this information on your homework problem or an engineering design problem, then you can try using "hear say" info. But for serious, industrial applications you should only rely on recognized experts.
#3 Guest_Macca Chiu_*
Posted 07 May 2005 - 03:33 PM
Thanks a lot for the information.
I have sent emails to the suppliers to ask about it.
regards
macca
regards
macca
Aspen Flare System Analyzer (Training Material)Started by Guest_opel_* , 22 Feb 2016 |
Material BalancingStarted by Guest_IluvChem_* , 10 Jul 2023 |
Answered
Material Balance 3 Seeds And 1ProductStarted by Guest_chemtoli_* , 29 May 2023 |
Pipeline Material SelctionStarted by Guest_BabRafiq1_* , 06 Sep 2022 |
Material Of ConstructionStarted by Guest_R_Gowtham_* , 28 Sep 2022 |
