Hello
Apologies for the vagueness of my process description. The process fluid is a hydrocarbon stream containing C
1- C
10 compunds with H
2S impurities. The vessel is a reboiled stripper that removes the methane, ethane, ethylene and H
2S from the hydrocarbon liquid stream. Unlike conventional strippers, there is no external stripping gas used. The stripping vapour is generated by reboiling the bottom product.
With the Kremser equation I hope to determine the number of stages in the stripper and also do a material balance at each stage. I have set up a spreadsheet with key flowrates and process parameters.
The process has been simulated in Hysys and I am using the process parameters like temperature, pressure and flowrates from the simulation
I need to calculate the k-values for the key components. I can do this by henry's law, K = H/P. However, I need to get the regression co-efficients of each component and then use a suitable correlation that relates H to temperature.
Reboiled Stripper Data.xlsx 137.1KB
78 downloads
