Flow Rate Calculation
Started by , May 12 2011 10:47 AM
Posted 12 May 2011 - 10:47 AM
Hi guys, how am i suppose to determine the flow rate of a 1/2 inches pipe, venting from a 4 bar vessel tank into atmosphere? The gas is oxygen gas. What formula should i used? thanks...
Posted 12 May 2011 - 11:50 AM
Sabah:
First and foremost, I have to presume you are a chemical engineering student who already has fluid mechanics under his belt – and I also presume that this homework assignment is related to that.
Therefore, I direct you to the following elementary – but very important details about this problem on which you should take special note:
- The fluid in question is a gas;
- The driving force (pressure drop) being applied is greater than 2:1;
- The fluid is obviously flowing at sonic velocity.
If you are having trouble understanding sonic flow of gases (or “choked flow”), I recommend you go to visit Milton Beychok’s webpage at: http://www.air-dispe...m/feature2.html
You can also find many sources of this same subject in our Forums by using the SEARCH feature. Try the terms sonic, choked flow, gas velocity.
Posted 24 May 2011 - 06:55 AM
Flow rate(cubic meter per second) = Cross sectional area of pipe(square meter) * Velocity of gas through pipe(meter/second)
Both cross sectional area and velocity you can easily measure and it will give you actual flow rate of gas.
Generally recommended velocity of gases for short distance pipe (length of pipe is less than 1000m) is around 20 m/s.
Posted 24 May 2011 - 07:59 AM
Krunal:
I am afraid that the answer is much more complex than your simplistic approach. You fail to either read my post or follow my recommendations:
- The fluid is obviously flowing at sonic velocity;
- Read Milton Beychok’s excellent treatise on sonic (choke) flow of compressible fluids.
Posted 24 May 2011 - 11:25 PM
Mr. Art,
Sir there are many instruments available by which we can measure air velocity but as you say it will only useful if the process is operated at steady state.
regards,
Shah Krunal
regards,
Shah Krunal
Edited by Krunal Shah, 26 May 2011 - 04:46 AM.
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
