Koh Dissolution
#1 Linas
Linas
  • 4 posts
Posted 05 August 2011 - 06:42 PM
I have short question regarding simulating a dissolution reaction in Aspen plus.
KOH(s)--> KOH(aq) DH=-57.6 kJ/mol
When I define KOH(aq) as a component, I supply mol wt, DHf, DGf, density, and melting point. When I run it, it asks for vapor pressure data. I used all kinds of reactor models on ASPEN but get the same error message.
Aspen has KOH, KOH:A, KOH:B, and KOH*W (KOH with one molecule of water of crystalization). I am not sure how to look up what KOH:A and KOH: B are.
My goal is to recover the heat from this reaction. I have manually calculated this using DH but would like to add it to my ASPEN flow sheet.
Edited by Linas, 12 August 2011 - 10:34 PM.
#2 milenkom
milenkom
  • 40 posts
Posted 10 August 2011 - 04:46 AM
KOH(s) + H2O(g) --> KOH(aq) DH=-57.6 kJ/mol
I want to know I can specify KOH(aq) as a component. When I specify KOH(aq), I supply mol wt, DHf, DGf, density, and melting point. When I run it, it asks for vapor pressure data. I used all kinds of reactor models on ASPEN but get the same error message.
You'll have to use electrolyte chemistry for this one. In components section there you can specify electrolyte chemistry, ions, reactions and also check the box calcutate dissolution heat. It's possible I think but it's not something I'm very familiar with. I used to simulate HCL scrubbing with dissociation of gas HCL into water, but I always had errors when I specified reaction for absorber block.
#3 Linas
Linas
  • 4 posts
Posted 12 August 2011 - 10:39 PM
Thanks for your reply. I am intersted in dissolution of KOH and not its dissociation because I would like to recover the heat of dissolution. I will look into using electrolyte chemistry.
