I am a chemical engineering student working on my final year project which is the "production of different grades of lube base oil through the vacuum distillation of atmospheric residue". The products coming out of my column are GAS OIL , SPINDLE OIL, SAE-20 & SAE-40 whereas the vacuum residue leaves the bottom.
I am using a tray column and after having literature survey I fixed the following parameters for my column:
- Flash zone pressure = 95 mm Hg
- Flash zone temperature = 750 F
- top pressure = 50 mm Hg
- Number of trays = 20
- Spindle oil draw tray = 4th tray
- SAE 20 draw tray = 8th tray
- SAE 40 draw tray = 12th tray (trays are numbered from top to bottom)
- Pressure drop per tray = 3 mm Hg
Can anyone suggest me a scheme for extracting the desired amount of heat from my column through top reflux and pumparounds?
Attached are the temperature/pressure profiles and other relevant information.
I will be very thankful for your kind help.
Raza.
