I have a question regarding the topic of equivalent length. Le donates equivalent length. then what does Le/D donate? what is the significance of Le/D as a whole? Le is used for calculation of pressure drop, but what does Le/D stand for and its importance?
Thank you. Waiting for someone to answer.
Equivalength Length
Started by Process Engineer_DES, Sep 06 2011 05:03 AM
fluid fluid mechanics fluid dynamics fluid flow pressure drop equivalent length length of pipe
Posted 06 September 2011 - 05:03 AM
Posted 24 September 2011 - 07:23 AM
http://www.engineeri...thod-d_804.html
This question is a very basic one and I would advise to find text book on fluid dynamic.
Let you try to get a copy of Crane TP 410.
Posted 24 September 2011 - 09:07 AM
Athar,
Read the article on "Cheresources" provided as a link below:
http://www.cheresour.../eqlength.shtml
Posted 26 September 2011 - 01:29 PM
Dividing the equivalent length Le by the pipe inside diameter (i.e. D) is a very useful concept because for a given type of fitting - say a long radius elbow - the ratio Le/D is virtually constant. This means that you do not have to tabulate and remember Le values for every different size available. You need only to remember the Le/D ratio for the type of fitting and then you can get the Le by multiplying by the actual pipe ID.
The alternative to using Le/D values is to use the resistance factor, or K-Value. If you use accurate K-Values that is probably the best way to go, but the difficulty is that K-Values vary with Reynolds number and with pipe size. On the other hand the Le/D ratio is almost constant for all Reynolds numbers and all pipe sizes. When you consider that the K-Value (and the Le/D ratio) for a typical fitting like a reducer will vary from manufacturer to manufacturer by 50% or more, and even within a batch from the same manufacturer, it is a fruitless exercise to try to be too accurate in calculating the pressure drop through fittings.
Posted 28 September 2011 - 02:02 AM
Well explained in case of revamps you have the isometrics available for accuracy to maintain and in case of grass root design you can keep some safety margins.
![]() Kettle Reboiler LengthStarted by Guest_Lyne_* , 26 Feb 2024 |
Equivalent Length CalculationStarted by Guest_T_bag_* , 19 Feb 2024 |
![]() Psv Inlet Pipe LengthStarted by Guest_R_Gowtham_* , 13 May 2022 |
Lng Tubing Line Length Standard For Pressure/differential Pressure SenStarted by Guest_Younghun Kim_* , 10 May 2021 |
