Psv Superimposed Backpressure Vs. Design Pressure Of Relief Header
Started by Beergson, Nov 23 2011 02:23 AM
Posted 23 November 2011 - 02:23 AM
I'm working on plant revamping project and during relief analysis I found that superimposed backpressure generated inside relief header during relief scenario will exceed design pressure of relief header which is equal to 3,5 barG.
The question is - should relief header design pressure be increased to maximum superimposed backpressure or not?
Posted 23 November 2011 - 06:01 AM
Beergson,
Yes, the design pressure of your relief header should be greater than the total backpressure that the header can see. For providing design pressure data the highest backpressure in the relief system components should be utilized but this is purely an academic exercise specifically when you are talking about piping. Piping is generally given in pound rating and if you and your piping engineer agree for a 150 # rating then specifying the design pressure of the piping as 3.5 barg or even 4.5 barg becomes an academic exercise because the MAWP of a 150 # rating pipe is much higher than 3.5 barg.
The vessel such as the Flare KOD is a different story. Here, although 3.5 barg as DP is a very well known rule of thumb or recommendation as per API STD 521 it is possible to have the Flare KOD design pressure to be higher. API STD 521 in fact mentions it as the minimum value for the DP. Shell mandates the DP to be 7 barg if there is no water seal vessel in the flare system.
Hope this helps.
Hope this helps.
Posted 23 November 2011 - 06:41 AM
Dear Ankur,
Thanks for Your prompt reply.
But what about builtup backpressure? If static (superimposed) is 20 kPaG and builtup backpressure is 400 kPaG, what should be minimum design pressure of relief header - 20 kPaG or 420 kPaG?
Posted 23 November 2011 - 07:24 AM
Dear Ankur,
Beergson,
It should be 400+20=420 kpag.
Fallah
Posted 23 November 2011 - 07:44 AM
Ankur,
It really depends on piping material and piping design temperature and therefore couldn't be generalized.
Fallah
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
