Actually the "Luxembourg" info represents the European Union limits of glcs, as
http://whqlibdoc.wh..._06.02_eng.pdf confirms (found just now), extending the data for other pollutants too. The disadvantage for the dispersion model is that only NO2 is given as hourly average. Conversion of glc (average of t1) to glc (average of t2) looks possible, yet Nonhebel's book on air pollution control (~1974) did not present this matter clearly (as I remember).
Bypassing improper comments in previous posts, EPA's standards on air quality could help the specific case in a similar way as the glcs by EU. However check is needed, e.g. the case of allowable NO2 glc below.
According to EPA this is 100 ppb (hourly average), which means 100E-9*46 kg/kmol air = 100*46/22.4 mg/ Nm3 air = 205 mg/Nm3 = 205000 μg/Nm3, versus 200 μg/m3 (hourly average) per EU. EPA does not mention glcs, but it must be so. Is there an arithmetic mistake in the conversion realized? If EPA's figure were 1000 times less, the two values would be practically identical.
Similarly EPA accepts 54 ppb (yearly average), that is 54*E-9*46/22.4 kg/Nm3 = 111000 μg/Nm3, versus 40 μg/m3 (yearly average) per EU. This may not concern dispersion model though.
So comments on the above differences are welcomed. More data on glcs would be also useful.
Edited by kkala, 06 January 2012 - 02:20 AM.
