Currently, I am working on proposal of Ammonia flare system project for one of the client based in GCC. I have an experience on the HC flare system.
There are 2 flare header coming to the ammonia flare system as below.
Refer attached sketch for easy understanding.
- PSV discharge having liquid + gas stream
- PSV discharge having only Gas stream
The PSV discharge having liquid + gaseous stream will be transferred to the Flash tank for separation of liquid & gas stream. The separated liquid stream will be sent to ammonia storage tank & Gas stream connect with the main gas flare header & transferred to Ammonia KOD.
I have following question regarding the system, may u consider silly also
- Why water seal drum is not considered to in this design? HC flare system have a separate KOD & water seal drum for adequate protection against flash back form the flare tip while Ammonia have only KOD integral with flare stack.
- What is reason for providing the steam tracing to the flash tank?
