Flare Load Calculation
Posted 25 November 2011 - 05:58 AM
I want to know that while performing flare load calculation only rated flows of different PSV's for the respective governing case will be added up or relief scenarios that are not governing for PSV design but will effect the KOD sizing should also needs to be considered ?
For example:
selection criteria for PSV-1 was fire case :
Case-1 - Fire case, required reliving area=2 sqr inch, rated flow = 5000 lb/hr of gas
Case-2 - Blocked discharge (liquid relief), required reliving area = 1.5 in2, rated flow = 200 gpm of liquid
Selection criteria for PSV-2 was blocked discharge liquid relief. as:
Case-1 fire case, required relief area = .5 in2, required flow = 2000 lb/hr
Case-2 - Blocked discharge (liquid relief), RRA = 1in2, RF = 2000 gpm of liquid
Now my Q is whether flare load is 5000 lb/hr of gas and 2000 gpm of liquid (considering only govrning cases)
or it should be 7000 lb/hr (i.e. 5000 +2000) of gas and 2200 gpm (i.e. 200 + 2000) of liquid.
or i have to look for the simultaneous relief scenarios ?
Kindly suggest.
Posted 26 November 2011 - 07:44 AM
Dear all
For example:
Kindly suggest.
vikramltv,
In general, the largest flare loads from multiple relief valves result from general failures such as fire, power failure or cooling water loss.
Hence, to obtain flare load for each failure you should sum up relief loads of those PSVs would simultaneously be opened due to such failure.
Fallah
Edited by fallah, 26 November 2011 - 07:46 AM.
Posted 26 November 2011 - 09:57 AM
one more thing I want to know if we can route an liquid relief PSV discharge directly to close drain system instead of sending it to flare header..and if it is done then what will happen in fire case when the same PSV will relief gases/vapor? If it is a common industry practice or violation of some standard?
Posted 05 December 2011 - 01:33 AM
You are considering relief valve for two cases. One is liquid discharge & other is gaseous discharge.
Common KOD is used to prevent liquid carry over in flare system. The liquid collected in KOD is finally discharge to closed drain system or slope header. You should connect the PSV discharge to flare header only not Closed drain system. It is not safe to divert the gas to closed drain system.
Posted 07 December 2011 - 05:35 AM
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
