why we need to compress fuel gas before sending it to the absorber column.
why only c3 is absorbed but very less amount of lighters in absorbent which is debutanier bottoms
Absorption
Started by bluewater, Dec 03 2011 09:27 AM
Posted 03 December 2011 - 09:27 AM
Posted 06 December 2011 - 09:21 AM
bluewater,
If you want a reply to this, you need to provide a bit more information, so we can understand what you are talking about. Take the time to send in some pressures, temperatures, compositions, and sketch of the system, with some indication of what its purpose is.
Even without all this, I can raise this point. I don't understand why you ask why lighter components than C3 are not absorbed.Only ethane, ethylene and methane are lighter hydrocarbons than C3. Why would you try to absorb methane from fuel gas? And to absorb ethane you would need high pressure and low temperature in the absorber.
Paul
Paul
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Solvent Carryover Emissions In Absorption ProcessStarted by Guest_TeeEng_* , 24 Oct 2023 |
Which Thermodynamic Model In Aspen To Be Used For Ammonia Absorption IStarted by Guest_Nikhil Shipure_* , 11 Sep 2019 |
Amine Co2 Absorption UnitStarted by Guest_mrh2016_* , 17 Apr 2018 |
Chemical Absorption Of So3 (Sulfuric Acid Making)Started by Guest_Franwis_* , 22 Dec 2021 |
