During ethene production from ethane by steam cracking:
1. Do reactions reach anything like an equilibrium?
2. Are reduced pressures used in the furnace to drive the equilibria forward - if so, what sort of pressures are used?
3. Are appreciable amounts of coke produced and, if so, is it used as carbon black for car tyres?
Many thanks
Chris
Ethylene Production
Started by Guest_Guest_Chris_*, Sep 14 2005 03:44 AM
#1 Guest_Guest_Chris_*
Posted 14 September 2005 - 03:44 AM
Posted 16 September 2005 - 02:04 AM
1. Residence time in the cracker heater is very short, around 0.05 s. There are a number of reactions involved, for example:
ethane <=> ethylene + H2 <=> acethylene + H2, but also addition reactions that ultimately lead to coke.
So the longer the residence time, the more ethylene is converted into acethylene and coke. If you would wait long enough, you would have only coke and H2 left.
2. Pressures are relatively low (a few barg). Further reducing the partial pressure is possible but not very attractive: the equipment must be large... The steam dilution is used to avoid addition reactions which would ultimately lead to coke.
3. One of the objectives of the selected process conditions and equipment is to prevent coke formation as much as possible. Still. a heater needs to be decoked about once a year. This is often done on-line by burning off the coke by sending in a steam/air mixture. Some operating companies remove the coke mechanically, but this means that flanges must be opened etc. So depending on the decoking method, there is either no or a limited amount of coke produced. I would say the coke formed is anyway not of a high quality, e.g. when compared with coke produced in the delayed coking process in refineries.
If you want to know more, maybe you can find a copy of the book "Ethylene - a Keystone to the Petrochemical Industry", by Ludwig Kniel e.a.
#3 Guest_Chris_*
Posted 16 September 2005 - 04:37 PM
QUOTE (gvdlans @ Sep 16 2005, 02:04 AM)
#4 Guest_Chris_*
Posted 16 September 2005 - 04:42 PM
Many thanks for your reply.
I guess the somewhat lower pressures in the cracker help drive the equilibria involving ethylene production forward to a degree.
Chris
Chris
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Reactive Distillation For Dimethyl Carbonate ProductionStarted by Guest_JakeHollier_* , 02 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
