Hi Everyone,
I would like to get some of your opinions regarding the use of conventional PSVs used in a cascaded arrangement, where the outlet of the PSV is relieved upsteam around an isolation valve back into the line.
Being exposed to the industry, I found it common practise for conventional PSVs at tank inlets and outlets to be cascaded back into the tank. From API520, the allowable back pressure in these scenarios should be less than or equal to the overpressure set on the PSV.
For a single valve arrangment around a tank outlet the overpressure would be 110% and the PSV would have a back pressure equal to the tank head. So for a large tank with a head of 175kPa the CSP should be at least 1750kPa. However, this setting would make it difficult to have multiple PSVs cascading in a series.
Have you ever had any bad experiences using PSVs with excess backpressure while still being able to relieve theoretically under MAWP, such as using a conventional PSV with a CSP of 175kPa in the example above?
Conventional Psvs In A Cascading Arrangement
Started by s'more, Jan 12 2012 10:14 PM
No replies to this topic
Posted 12 January 2012 - 10:14 PM
Two Psvs Have More Or Less Same Set PointsStarted by Guest_johneyissac98_* , 16 Jan 2024 |
Answered
Multiple Psvs Relief RateStarted by Guest_fmalik_* , 02 Dec 2023 |
Set Pressure Of Multiple PsvsStarted by Guest_Vegeta_* , 28 Mar 2023 |
Credible Scenario For Pressure Safety Valves (Psvs)Started by Guest_panagiotis_* , 13 Dec 2021 |
Answered
Conventional Distillation Column DiscussionStarted by Guest_panoskagiou_* , 29 Mar 2019 |
