Pipe Protection - Fire Case
Started by Bill B, Jan 25 2012 07:21 AM
Posted 25 January 2012 - 07:21 AM
We like your input on the following, which seems to frequently surface. We are evaluating RV protection of piping that are in tankwagon and railcar loading areas - i.e. there is a potential source of a fire from the trucks and/or rail car moving equipment.
Is piping usually provided fire protection in this case. In cases above, system could indeed be blocked in liquid, and a source of a fire could be present.
Regarding Code, ASME 31.3 states "Provisions should be made to safely contain or relieve any pressure to which the piping may be subjected", and "Pressure relieving devices required ... shall be in accordance with ... Section VIII ...... The terms design pressure and piping system shall be substituted for maximum allowable working pressure and vessel, respectively, in (the Section VIII Code)". This confirms that piping must be RV protected.
The question then becomes "Is process piping normally protected in the event of a fire scenario"?
I would welcome your thoughts. Thanks.
Posted 25 January 2012 - 07:40 AM
Bill B,
The answer is: Normally no, but if piping system containing more than around 2-3 tons flammable gas, or liquid HC, or liquified HC can be isolated and also can be exposed to fire it is needed to consider PSV fire case for protection of that part of piping has been isolated against overpressure due to fire scenario.
Fallah
Posted 25 January 2012 - 10:01 AM
Thanks! Can you provide a reference for the "2-3 tons of flammables"?
Bill
Bill
Posted 26 January 2012 - 01:53 AM
Bill
Bill B,
Actually the concept behind this criteria is the fact that an isolated part of a piping system containing such amount of flammable gas/liquid above a specified value tends to be similar to a pressure vessel needs protection against fire scenario. I have seen these values in engineering practices of some oil&gas companies.
Fallah
Posted 26 January 2012 - 09:18 PM
1. As mentioned by fallah, PSV for protection due to fire is not being considered. Since piping is normally connected to pressure vessel which is normally PSV protected. If the vessel is not overpressure, piping will also be not subjected to overpressure.
2. The protection as per ASME Code is for overpressure due to other reasons such as blocked discharge of a pump where the shut-off pressure exceeded the piping design pressure or possibility of thermal expansion due to blocked-in situation.
Edited by S.AHMAD, 26 January 2012 - 09:18 PM.
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
