Dear all,
We have existing GRP vessel with stainless steel [either 304 or 316 - not sure which one] agitator in it. We are planning to charge about 37% by w/w Hydrochloric Acid and mix it with metal oxides. As this is the pilot plant trial we want to use the existing equipment and control the cost i.e. we don’t want to spend money in coating the agitator with PTFE or Polypropylene[PP]. I understand that the reaction of HCl with metal will produce Hydrogen and metal chloride and not sure if we consider agitator as the consumable item. We intend to run this plant for about 6months [24hrs] and not sure if we can use agitator as a consumable item.
Please note that we hall all other equipment/pipework are made up of PP except agitator. Could anybody let me know if I can use agitator without coating?
KS
Stainless Steel Agitator As Consumable Item For 37% Hcl?
Started by KS2011, Feb 09 2012 03:16 AM
Posted 09 February 2012 - 03:16 AM
Posted 27 March 2012 - 09:47 AM
I would think it would; from what I've found in my (very brief) search, 37% HCl will eat pretty much everything other than tantalum and zirconium. (http://www.tantaline...osion_Chart.JPG)
http://www.bssa.org.....php?article=30
Google corrosion charts for HCl. I know there's a multitude of information for sulfuric (which my plant uses), and would imagine that hydrochloric has similar info available online.
Edited by Stephen80, 27 March 2012 - 09:52 AM.
Posted 27 March 2012 - 10:06 PM
From my experience with stainless steels and HCl, your agitator probably wouldn't last six months...
Posted 29 March 2012 - 12:12 AM
Consider this resource to support your query . SS and HCL won't last!
Consider CS +coating .
http://www.chemtech-...acid-plants.php
Hope this helps
Hope this helps
Edited by breizh, 29 March 2012 - 12:41 AM.
Max Wall Temperature Stainless SteelStarted by Guest_ChristianColombini_* , 23 May 2024 |
Cost Factor/index Table For Mocs Like Carbon Steel, Glass Etc.Started by Guest_daraj_* , 29 Aug 2021 |
Spark Potential Stainless SteelStarted by Guest_kangas_* , 03 Jun 2021 |
Temperature Profile Through Stainless.Started by Guest_LittleFish_* , 17 Nov 2020 |
Equation For Heat Loss Through Carbon Steel PipeStarted by Guest_Process EngrPsh_* , 11 Dec 2019 |
