Asme Sec Viii Ug-127 And Ug-131: Kd Vs Kr
#1 seetheforest
seetheforest
  • 5 posts
Posted 13 March 2012 - 03:34 PM
I have a question that has been bothering me for a while. In UG-127(a)(2)(a)(3), ASME states that rupture disks must not exceed a coefficient of discharge, KD, of 0.62.
However, I must say that I am mystified by the difference between the coefficient of discharge, KD, and the flow resistance coefficient, KR.
Moving to section UG-131(e), there is a definition of the coefficient of discharge and an equation (Wt = 51.5 A*P) to which the coefficient of discharge can be applied (Appendix 11). However, in UG-131(k)-® ASME starts defining the flow through a burst rupture disk in terms of KR--flow resistance.
My question boils down to... what's the difference between KR and KD? Can I use KR in the Wt = 51.5 A*P equation?
Or, more generally, if I calculate my own theoretical flow through a valve or an orifice, should I multiply that value by the appropriate KD or KR that I can get from the valve manufacturer? And why does UG-127 set a limit for the rupture disk KD if rupture disks are always characterized by KR?
I'm somewhat confused. :)
Edited by seetheforest, 13 March 2012 - 03:34 PM.
#2 Shivshankar
Shivshankar
  • 257 posts
Posted 14 March 2012 - 03:08 AM
Hi Seeforest,
Please go through article (blog ) by ankur on, read it carefully, I hope you will understand the difference between Kr and Kd and when to use it.
http://www.cheresour...ngineers-part-2
Shivshankar
