Who Can Tell Me The Meaning Of "fast Down" Here?
Started by , Apr 01 2012 08:05 AM
Posted 01 April 2012 - 08:05 AM
Injector system: 2000ml capacity, with twin walls to allow heating cooling;feed rates from 0.07 to 7ml/s; fast down,with index and control system.
thanks in advance!
thanks in advance!
Posted 01 April 2012 - 01:16 PM
This query has no explanation as to what it is about.
Kindly express yourself in understandable, specific english in order to try to make out what it is that you are writing about.
Posted 01 April 2012 - 11:18 PM
thank you very much!
please find the original text in attachment:
Posted 04 April 2012 - 09:21 PM
2 all friends, who can help me, million thanks
Posted 05 April 2012 - 09:12 AM
I believe you had better ask clarification from supplier. I can imagine that "fast down" means that flow rate of injector system can quickly go down from 7 mL/s to 0.07 mL/s (quick response when flow rates need to change). But is it sure? these matters should be made clear before order.
Edited by kkala, 05 April 2012 - 09:15 AM.
Turndown % MeaningStarted by Guest_james.corrobro@gmail.com_* , 03 Apr 2021 |
Path Meaning In Indirect Bath HeaterStarted by Guest_pinakini_* , 31 Aug 2019 |
![]() Meaning Of Pipe Class And Pipe RatingStarted by Guest_inkar_* , 27 Oct 2018 |
What's The Meaning Of Floating In Flare System?Started by Guest_Poet_* , 24 Aug 2017 |
What Is The Meaning Of ''effective Volatile Content''Started by Guest_Krish117_* , 08 Oct 2015 |
