I work on a gas plant and have been working with Hysys since last time. I am trying to simulate LPG recovery unit in Hysys. I got propane refrigeration unit to recover HC from export gas due reducing temperature of inlet gas from -15 C to- 38 C and LT separator to separate glycol+water, HC from gas. I simulated it in Hysys and specified inlet feed gas composition at operating temperature and pressure.
Inlet gas to the chiller:
T = - 15C
P= 400 psig
Q= 34MMSCFD
COMPONENTS MOLE MASS FLOW
FRACTION (kg/h)
Methane 0.856 23300.09
Ethane 0.082 4183.63
Propane 0.0321 2398.429
i-Butane 0.0035 347.24
n-Butane 0.0054 532.83
i-Pentane 0.0013 163.2
n-Pentane 0.0009 105.95
H2O 0 1.513
Helium 0 0
Nitrogen 0.0135 643.10
CO2 0.0053 394.65
EGlycol 0 0.0074
After LTS I got a gas stream with next composition (by Hysys):
T = - 38 C
P= 390 psig
FRACTION (kg/h)
Methane 0.8711 23136.46
Ethane 0.0793 3948.678
Propane 0.0256 1872.44
i-Butane 0.0020 189.9
n-Butane 0.0024 232.56
i-Pentane 0.0003 34.58
n-Pentane 0.0001 16.27
H2O 0 0.066
Helium 0 0
Nitrogen 0.0138 641.96
CO2 0.0053 385.02
EGlycol 0 0.0009
As you can see I still got a lot of C3-C5 in gas stream from LTS. And as result Hysys calculated 2% more C1-C2 product, 50 % less C3-C4 product abd 35% less C5+ product after fractionation train if compare with my gas plant report.
I think it depends with excess of C3-C5 components in the export gas (gas stream from LTS). Recovery of HC depends from operations T and P, all conditions are the same ason plant. What it is wrong?
Edited by Dmitry, 11 May 2012 - 04:50 AM.
