Desalination Of Seawater Using Ro Membranes
#1 keby9vam
keby9vam
  • 30 posts
Posted 05 June 2012 - 10:44 PM
I'm currently working as an intern in an oil and gas R&D company in Malaysia. I was given the task to research on desalination of seawater, in which the seawater will be injected into the oil reservoir for tertiary enhanced oil recovery. The main purpose of this desalination is to reduce/remove Magnesium, calcium, iron, and sulphates from the feed seawater to the required amount using the reverse osmosis (RO) method. Also, another aspect of concern is whether RO can be controlled and how.
At the moment, I'm trying to research on the working principles of a RO membrane filter in order to understand how the system works. Also, I am trying to find a membrane that facilliates Magnesium, calcium, iron, and sulphates removal. However, I'm not sure as to where I should proceed next. Should I proceed with the design aspects of the membrane? Is there any sort of tips you could provide? Your help is deeply appreciated.
Vik
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 06 June 2012 - 01:23 AM
Vik,
Suggest you read the following:
Chapter 7, Reverse Osmosis; "Fundamentals of Salt Water Desalination" by Dessouky and Ettouney
#3 keby9vam
keby9vam
  • 30 posts
Posted 06 June 2012 - 08:23 PM
Hi Mr. Ankur,
Thanks for the suggestion. It was very helpful indeed. Thank you for your time.
Vik
