Dear colleagues,
I am a salesman of a fabrication company. Company has lots of experience in fabrication of gas flares but the design capabilities leaves much to be desired.
The problem is. Wet natural gas in a pipeline from x-mas tree to an early gas facilities has a pressure of 120 bara. There will be emergency flares every 6-7 km. Time of pressure relief via burning gas in one section of a pipeline is about 15 minutes. Estimated tip diameter is 250 mm; stack height is 35 m. But engineers can not calculate wall thickness of a flare stack for such a valuable pressure because they even have no design model for that. Please support me with some information on this problem in order to estimate the thickness.
Thank you!
Flare Stack Wall Thickness Calculation
Started by Andron, Jun 07 2012 01:59 PM
flare thickness stack
No replies to this topic
Posted 07 June 2012 - 01:59 PM
