Design Of Carbon Filtration In Pharmaceutical Industry
#1 vijji
vijji
  • 26 posts
Posted 30 August 2012 - 12:38 PM
Hi all,
Any body suggest how to design the carbon filtration after treament of organic solvents. Say 10 Kg activated carbon used for 1000 lts solvent. Could anybody suggest to design a carbon filtration equipment.
  • 7,066 posts
Posted 31 August 2012 - 12:02 AM
Hi
Not clear what you are asking ! Let you use the search button for adsorption process . Now you still have the possibility to perform tests in your lab.
#3 vijji
vijji
  • 26 posts
Posted 01 September 2012 - 11:48 AM
Hi, In pharmaceutical industry carbon treatment will do to improve the color of product by adsorption process..that is different topic..here my qustion is filtration of the carbon using Leaf filter, please guide the calcultion method to filter the mass (1000 Lts methanol+Product+10 Kg carbon) in approx.4 hours. Pressure will be 2 kg/cm2.
#4 breizh
  • 7,066 posts
Posted 01 September 2012 - 06:53 PM
http://www.filtratio...tion/sld001.htmHi ,
Consider this resource to support your query , review all the material attached:.You may find additional info in Perry's chemical handbook .
Anyway you need to perform lab test to characterize the resistance of the product , the media.
Vendor could assist .
Hope this helps
Edited by breizh, 02 September 2012 - 06:59 PM.
#5 S.R.Shah
S.R.Shah
  • 113 posts
Posted 02 September 2012 - 11:21 AM
In Pharmaceutical Industry ,Carbon treatment has been given to improve the colour and transperency of Liquid at hot temperatur to facilitate good absorption Such as in case of Cephalexin Hydrochloride
In India; Generally Sparkler Filter -Leaf Filter is used .There are standard Models available.Please consult manufacture to select standard Model for your duty.
SRShah
