I want to design a caustic wash unit to remove the H2S of naphtha. But I don't how I can proceed. Please can you give me some informations about it? I want to know the optimal conditions (temperature, pressure, caustic percentage) to realize the reaction also. thanks a lot.
Caustic Wash Unit
Started by emiso, Sep 17 2012 04:15 AM
Posted 17 September 2012 - 04:15 AM
Posted 18 October 2012 - 02:56 PM
Emiso,
as you haven't given any information about the contaminants present in your naphta nor the specification of your product, I am assuming that you only have to remove the residual H2S to not fail the copper corrosion test.
For this, you may design a simple caustic wash, using a 10-20Be caustic solution.
The caustic circulation is between 15-20% of the naptha volumetric flow. It is necessary to use a mix device to provide contact between the naphta and the caustic solution (maybe a statical mixer or a mixer valve).
After this, the mixture caustic solution-naphta shall be separated by gravity in a settler. Upstream this settler, you may use a sand filter to polish the nafta avoiding caustic entrainment in the treated product.
In this treatment the temperature and the pressure are not concerns. You must only take care of high temperature to avoid caustic corrosion.
I hope this can help you.
Best regards, EngK
Best regards, EngK
Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
