Problem Statement:
Benzene is fed to a reactor in excess to promote the production of monochlorobenzene. the reactor products are fed to a condenser, where the choloro-benzenes are condensed. the condensate is seperated from the non-condensable gases in a seperator (flash drum) the non-condensables, hydrogen chloride and chlorine leave in the upper stream. Do a hazop on the upper stream, the parameters being temperature, pressure and flow. the node being point before the vavle.
this is what i have already done:
Guide Word
Deviation
Cause
Consequence
Action
More
High Temperature
Pre-heater products enter the flash at high temperatures.
Causes to high pressure.
HCl release.
Causes injuries.
No action. Event unlikely to happen.
Hot weather.
Low Temperature
Cold Weather.
This will result in insufficient vapour leaving the tower.
More
High Pressure
Valve stuck close
High Temperature
The increase in pressure could lead to an explosion.
There should be a pressure relieve valve installed.
