Slug Catcher Sizing
20 replies to this topic
#1 greatparesh
greatparesh
  • 4 posts
Posted 20 January 2006 - 04:16 AM
Daer all,
I am working on Design of a Slug Catcher, an equipment (3 phase separator) required in Oil & Gas Industry at the upstream (near Gas Wellhead) to separate gas/oil/water.
I have got a basic understanding of its design. But it will be very kind of you, if you can help me with followings
1. How to design a Slug Catcher (i mean what are the issues that need to be taken care of )?
2. Any previous design/operating data/ datasheet available with you.
Thanks & Regards
GreatParesh
#2 Guest_pipelineman_*
Guest_pipelineman_*
  • guestGuests
Posted 07 February 2006 - 06:14 PM
I need some help in this area also. Any help would be greatly appreciated.
#3 Guest_Guest_*
Guest_Guest_*
  • guestGuests
Posted 02 March 2006 - 05:40 AM
Paresh
From your posting, it appears you are catring to a single well(?). The very basic steps are:
1. Establish the slug size
2. Establish the slug frequency
3. Allow sufficient volume in teh separator (typically between normal level and high level setpoints) to accomodate this slug, at the same time ensuring that the slug volume can be disposed of before the next slug arrives.
You could also consider a slug contrl valve on teh separator inlet, which closes with increasing liquid level in the separator.
Better and more detailed means of minimising pipeline slugging, and simulating the same utilise dynamic simulators like OLGA.
#4 kay1
kay1
  • 12 posts
Posted 15 January 2007 - 08:41 AM
Please is there any book that gives full information on slug catcher sizing. I am so much interested to know it too. I will appreciate the details of a 2-phase slug catcher.
Regards.
#5 uetian98
uetian98
  • Inactive Member
  • PipPip
  • 11 posts
Posted 15 January 2007 - 08:16 PM
I am attaching my own spreadsheet for sizing of inlet seperator / Slug catcher.
Hopefully it would help.
didnt have much time else i would have removed its cometics defect.
tell me if it works
cheers guys
#6 palusa
palusa
  • 24 posts
Posted 16 January 2007 - 09:20 AM
greatparesh,
my experience is relevant to slug catchers along pipelines.
In this case, a couple of approach are advisable to estimate the volume of a single slug.
The first is based on the document SPE 15103 (Society of Petroleum Engineers 1986, that unfortunately I don't have) where correlations are presented by two authors: Scott and Norris.
Both express the length of expected slug (Ls, in feet) as:
ln(Ls) = A + B * [ln(Di)]c where Di is the internal diameter of the pipeline (inches)
According to Scott: A=-25.4144; B= 28.4948; c= 0.1
according to Norris: A= -2.099; B= 4.859; c=0.5
Plotting the 2 correlations vs the pipeline dia one can note that the results are almost identical.
The second is based on a Rule of Thumb of Duckler (sorry, no refs...). He indicated the min ans max slugs' length as Ls(min) = 12*Di and Ls(max) = 30*Di (Ls in feet and Di inches).
Duckler correlation gives by far smaller slugs volumes and is what I found to be of practical use in my projects.
Probably SPE correlations are more related to wellhead applications so could be more helpful for your case. However, unfortunately I don't have this specific doc.
Hope this could help you out.
_Lf_
#7 Guest_kwade_*
Guest_kwade_*
  • guestGuests
Posted 05 February 2007 - 08:47 AM
The steady-state software from Neotec (PIPEFLO) has feature for estimating the slug size, etc.
You would only need to go to undetake (expensive) dynamic calculations in OLGA if slugs were predicted in PIPEFLO.
#8 rohl55
rohl55
Posted 11 June 2007 - 09:30 AM
Hi Awais, I am also having a little trouble with slug catcher sizing. Could you help me out with your spreadsheet?. I read you were attaching it to your reply to Greatparesh and I will appreciate it you can share it again .... I am in a hurry really.
Best regards,
rohl55
#9 ROTATOR
ROTATOR
Posted 21 January 2010 - 04:39 PM
Hi Guys
Can you forward the Sizing Spreadsheet to me
cheers
#10 manchester
manchester
  • 64 posts
Posted 21 January 2010 - 08:43 PM
ROTATOR
I calculate finger type slug catcher with SHELL Design Engineering Practice as refference. Probably you can find the documents. I can't attached here due to the file is huge. However, I will send you the spreadsheet
#11
  • guestGuests
  • 0 posts
Posted 23 July 2010 - 07:59 AM
Gentleman,
Can i get ur spread sheet for my design verification please?
Thanks & Regards,
Subburam P
#12 luuquocdai
luuquocdai
  • 48 posts
Posted 23 July 2010 - 09:19 AM
Hi, friends.
Can you send me your calculation sheet?
I'm looking forward information from you.
Many thanks.
#13 djack77494
djack77494
  • 1,282 posts
Posted 27 July 2010 - 09:25 AM
Assuming the spreadsheet(s) are not proprietary, it would be MUCH more efficient to post them one time on this website rather than responding to many requests for private emails to individuals. Furthermore, that approach also allows all of the site readers to readily access any useful resources, which is an important function of the website.
#14 saiedeh
saiedeh
  • 12 posts
Posted 26 October 2010 - 07:31 AM
Hi Gentleman,
Could you please send slug catcher sizing spreadsheet to me as well?
Many Thanks
#15 Bindu Sudhir
Bindu Sudhir
  • 4 posts
Posted 22 February 2011 - 06:45 AM
Could anyone please send me the spread sheet for Slug catcher design. Thanks and Regards
Bindu
#16 hafeera
hafeera
  • 3 posts
Posted 01 February 2012 - 01:24 AM
Please send me the spread sheet for slug catcher design at
hafeera@gmail.com,
Hafeera
#17 Butterfly
Butterfly
  • 87 posts
Posted 01 February 2012 - 10:11 AM
Hello
Maybe this is not the case, if your slug catcher is very near the wellhead, but another thing to take into consideration when sizing is pigging. If you are going to pig the lines which go into the slug catcher, then it has to be sized for the slug volume which will arrive as a consequence of this pigging (and that will be a higher volume than the one that normally arrives).
Secondly, I didn't see any spreadsheet attached, so, following djack advice, dear uetian, could you please attach it here??
#18 Maxito
Maxito
Posted 13 March 2012 - 07:09 AM
Could someone send me the spreadsheet too please.Thanks,
Janice
#19 Profe
Profe
  • 316 posts
Posted 13 March 2012 - 08:12 AM
Hi all interested in this subject.
This link http://es.scribd.com...e-Slug-Catchers will send you to the method of design Slug Catchers
I think this will be useful
Edited by Profe, 13 March 2012 - 08:21 AM.
#20 tarang.tushar1
tarang.tushar1
Posted 26 November 2012 - 11:56 PM
can u plz send me the spreadsheet.
Thx in advance
#21 Ceng
Ceng
  • 33 posts
Posted 27 November 2012 - 12:51 AM
I want the spread sheet too; if it is possible
thanks
