Temperautre Change Due Flare Radiation Intensity
Posted 10 February 2013 - 02:05 AM
Posted 10 February 2013 - 04:58 AM
Posted 10 February 2013 - 05:39 AM
in the meantime you can do two things:
- search in the forum
- google "conduction of heat in solids calculation excel"
good luck ![]()
Posted 10 February 2013 - 07:33 AM
Does it really need anything more than a sun shield?
Not sure if the following is useful since its not really exactly what you want...
Edited by thorium90, 10 February 2013 - 07:59 AM.
Posted 12 March 2013 - 07:59 AM
The topic has been stagnant for a month. Below are some notes, subject to criticism and additions, for want of something better.
1. Radiation is practically transparent to ambient dry air, at least for distances like flare-ground. No heating of air is assumed to occur by travel of radiation through it (absorptivity=0, transmissivity=1).
2. Total radiation intensity Ko=1000 Btu/ft2/h = 3.15 kW/m2 on ground, composed of flame radiation Ko'=2.15 kW/m2 on ground just below flame center, plus solar radiation K''=1 kW/m2 at same time, as indicated on the attached "flareR.xls".
Flare flame at max length, corresponding to max flare discharge; solar radiation at maximum
Note: In case that mentioned 1000 Btu/ft2/hr do not include solar radiation, above has to be revised accordingly.
3. Radiation intensity K falling on the FFG shelter (flareR.xls).
3.1 Solar K" = 1 kW/m2
3.2 From flame K' =Ko'(h2/(h2+L2) per equation (20), para 4.4.2.3.3 (Radiation) of API RP 521 (4th ed, 1997). This can be also written as K' = Ko'cos2θ; see "flareR.xls" for meaning of h, L, θ.
3.3 Total K = K" + Ko'cos2θ; e.g. for θ=30° Κ= 1+2.15cos230° = 2.61 kW/m2
4. Shelter should be a closed room due to HVAC. Suppose a roof wide enough not to let radiation fall on peripheral walls. Help on estimating roof temperature profile (see post no 3 by geggio 1960) is welcomed. At present roof is assumed grey, of absorptivity say 0.4 (e.g. covered with thin aluminum sheet for protection), having uniform surface temperature and receiving heat 0.4*2.61~ 1.0 kW/m2. Unsteady heat conduction will rise temperature along roof thickness with time, on the other hand max flare discharge will be for some limited time. Surface temperature cannot be higher than (2610/5.672E-8)-1/4 = 463 oK = 190 oC, if I rightly understand Stefan - Boltzmann's low .
5.1 R Reed, "Furnace Operations" (Gulf 1976), Chapter 2 - Flaring and disposal, says for Ko=1000 Btu/f2/h onto grade of emissivity=0.80: max grade temperature is approximately 190 oC after 20 min exposure, but it can be as high as 90 oC at the end of 1 min.
5.2 Attached "flare001.pdf" (from web) mentions 31 oC temperature above ambient for radiation level = 1000 Btu/ft2/h, without explanations.
Edited by kkala, 12 March 2013 - 08:23 AM.
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
Flare And Venting SystemStarted by Guest_miz19_* , 10 Jul 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
