Hi all,
according to ASME VIII DivI, UG 99 is applicable for all pressure vessels for hydrostatic test 1.3 at design pressure and UG 100 for pnumatic test at 1.1 of maximum operating pressure.
Interpretation is very clear in para B ( UG 99), my question is about once the vessel is manufactured in workshop and hydro tested, stamped then why we need again hydro test after maintenance even their is no head or shell opening during the maintenance.
Pneumatic test at working pressure not enough instead of hydro test.particularly columns (like glycol cont actors and three phase separators).
Can any one explain it further.
thanks
Toor
Application Of Asme Ug 99 & 100
Started by Root, Feb 24 2013 03:02 PM
No replies to this topic
Posted 24 February 2013 - 03:02 PM
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
Asme Certification For Water Pipes, RotorStarted by Guest_Orzelgorskiego_* , 13 Jul 2023 |
Aiv Calculation - Application Of SffStarted by Guest_Reliefman_* , 22 May 2020 |
10/13 Rule ApplicationStarted by Guest_Alex1_* , 28 Apr 2023 |
In Search Of New Application Field For Conductive PolymersStarted by Guest_Thomas_WU_* , 24 Mar 2023 |
