there is a hypochloride reservoir tank. inlet nozzle of this tank for incoming hypochloride solution is at the top of tank. can we put overflow nozzle above of inlet nozzle?
Posted 07 April 2013 - 02:42 AM
Posted 07 April 2013 - 07:09 AM
You have to put it higher than inlet nozzle elevation if HHLL is to be located above inlet nozzle...
Edited by fallah, 07 April 2013 - 01:06 PM.
Posted 07 April 2013 - 07:44 AM
You have to provide overflow nozzle above the maximum safe filling height.
Jatin
Posted 07 April 2013 - 08:02 AM
excusme me. but it has discrepency with my mind!!!! if the overflow nozzle is above inlet nozzle and the tank comes to this line, it flows back into inlet line! am i right?
Posted 07 April 2013 - 11:06 AM
Appears in your mind the inlet line not only can bring the incoming liquid into the tank but also at the same time can play the role of the overflow line! Then if so, outgoing overflow liquid through the inlet line would come from which line?
Edited by fallah, 07 April 2013 - 11:09 AM.
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Nozzle Sizing In SeparatorsStarted by Guest_krishnamurthy_* , 30 May 2023 |
![]() Residence Time Dependence On Vessel Outlet NozzleStarted by Guest_lavlysuresh@outlook.com_* , 22 Mar 2023 |
Vapour Through Overflow Discharge LineStarted by Guest_kangas_* , 05 Jul 2021 |
