Calculation Of Methyl Acetate Leaking Though The 2" Piping From Pr
calculation of methyl acetate
7 replies to this topic
#1 haile123
haile123
  • 4 posts
Posted 25 April 2013 - 08:52 PM
To all,
I need your help. I am trying to calculate the Methyl Acetate leaking though 2" pipe from the pressurized storage tank. There is a glass in chamber foam, but the glass was broken, now the Methyl Acetate leaking through this 2" size. I want to calculate how much the vapor is releasing from the pressurized storage tank.
Please help me. thanks
  • 6,769 posts
Posted 25 April 2013 - 09:02 PM
This resource may help you :
http://www.air-dispe...om/usource.html
#3 haile123
haile123
  • 4 posts
Posted 28 April 2013 - 05:54 PM
beizh,
thank you for fast response. However, I used your link to run the calculation, it ended up strange number. The answer is about 0.11 lbs per second. it is about 396 lbs per hour that I believe it is high. can you please help?
ChokedFlowCAUS.png i used this formula to do calculate the MeAC leaks from 2" pipe.
thanks
#4 breizh
  • 6,769 posts
Posted 28 April 2013 - 06:35 PM
haile 123
Only you can perform the work because  you did not provide much information about the conditions ( P, T ,...)
Help yourself we will help you.
#5 haile123
haile123
  • 4 posts
Posted 28 April 2013 - 07:18 PM
Dear Breizh,
The temperature is 70F and the pressure is 3.88 Inches of Water with 22% of MeAC in the mixture.
Hai Le
#6 Art Montemayor
Posted 28 April 2013 - 08:36 PM
Hai Le:
We are not going to do your work for you.  We are here to help, not to do your work.
Submit your detailed calculations showing clearly your algorithm and math.  An Excel Spreadsheet is the best and most efficient way to do this.
#7 haile123
haile123
  • 4 posts
Posted 29 April 2013 - 10:42 PM
Art,
i wont ask you to do work for me. thanks anyway
hai
#8 breizh
  • 6,769 posts
Posted 29 April 2013 - 10:56 PM
Hai ,
Not much info , so my calculation based on assumptions  (2nd component water , % mol) for non chocked flow according to pressure ratio , gave : 0.049 lb/s
hope this helps.
Edited by breizh, 01 May 2013 - 12:59 AM.
