Hi
I am sizing PRV for fire case what is the formula to calculate wetted area of pipeline. All i found the formulas of wetted area calcuation for vessels.
Posted 25 June 2013 - 11:38 PM
Hi
Posted 26 June 2013 - 12:05 AM
I would say Pi*D*L .
Posted 26 June 2013 - 12:06 AM
Adil,
Pipes generally run full in single phase liquid flow when pumped. Even when encountering multi-phase flow the flow is generally never stratified with the most common flow patterns being annular, bubble and wave flow. Vessels on the other end are never operated completely filled. Hence the concept of wetted area applies to vessels only and not pipes. Pipe wetted area is thus the total surface area of the pipe
For any pipe the surface area is:
SA = pi*D*L
where:
SA = surface area,
D = Outside Diameter of the pipe
L = length of the pipe exposed
Ankur
Posted 26 June 2013 - 12:13 AM
Thanks breizh and ankur for elaborating in such a good way.
Posted 26 June 2013 - 01:01 AM
Ankur,
Allow me to make a correction on above statement:
There are many cases in which the vessels are operated completely full of liquid and are subject to be engulfed in a pool fire....
Posted 26 June 2013 - 03:20 AM
Hope this would be useful in your calculations. Mansari
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
