Pulsation Dampener In Gdu Unit
dehydration teg kimray
#1 processengbd
processengbd
  • 128 posts
Posted 10 July 2013 - 02:32 AM
Plant: TEG Dehydration unit
Do you guys have ever felt the need to use pulsation dampener after Kimray pump.
Posted 12 July 2013 - 02:10 PM
I have not had any pulsations with Kimray pumps that caused any problems.  Are you having any problems with the Kimray pump discharge?
#3 processengbd
processengbd
  • 128 posts
Posted 17 July 2013 - 05:13 AM
We had some problem with Glycol-Glycol heat exchanager(Welded Plate & Frame). It was leaking. We wanted to find out the causes. Our finding What if was.
1. Is there any condensate in the glycol after glycol flash separator.
2. Pressure fluctuation in the line.
The pressure transmitter showed pressure jump in the line so we thought it wold be nice to have a pulsation damper in the line.
It would be really helpful if you share your experience.
Thank you very much
processengbd
