Ours is a solid liquid reaction. Solids & liquids are charged at atmospheric condition. We obtain vacuum in the system with the help of oil ring vacuum pump. The vacuum pump require regular maintenance in terms of oil seal leakages and presence of powder in the pump.
We intend to use a vacuum catch pot and a demister pad to overcome this problem. The vacuum pump capacity will be 250 m3/hr.
Are we in the right direction/ or better suggestions are available. If, further data is required we can share the data.
