a picture of the pfd and the reaction kinetics have been added to this post.
i am trying to make the simulation produce more ammonia. as seen in the figure i have 19000 mol of hydrogen circulating in the stream, and nitrogen can be added from the N2 stream as needed. as seen in the kinetics of the reaction, ammonia in the feed slows down the reaction in a significant way. i tried multiplying the reactors, with cooling/heating in between, and even flashing the streams in between to get rid of the amonnia in the feed streams to the 2nd and above reactors. the feed enters the stream in 15000 pascal and 230 celcius degrees. i get a 85% conversion, but that is only when the feed streams contains 22 times more hydrogen then nitrogen, and the conversion is based on the nitrogen. I also tried having a duty exit stream from the reactor because it is an exothermic reaction, and that doesnt help either. i tried virtually cleaning the recycle stream completely from ammonia, which i think should result in great conversion.. but that doesnt help either..
any tips maybe? cause if 19000 mol of hydrogen are in the streams, alot more ammonia can be produced.
the reaction is:
1/2N2 +3/2H2 = NH3
the kinetics:
Screen Shot 2013-12-09 at 1.50.15 PM.png 12.92KB 6 downloads
the pfd:
Screen Shot 2013-12-09 at 1.45.39 PM.png 113.62KB 4 downloads
