Evaporator Clarification
evaporation evaporator seperation ethylene glycol water
#1 JinjoVitis
JinjoVitis
  • 5 posts
Posted 11 January 2014 - 01:53 PM
I was asked to design an evaporator for the separation of water form ethylene glycol. A series of evaporators were already present (as shown in the attached file) but I had some concerns having never done anything with evaporators before. For one I was confused with the evaporators shown in the figure as the evaporators I researched never had any packing or trays. Thus if this evaporator was to contain packing or trays which would be pro and cons for each. Finally would the evaporator be designed similarly to a distillation column.
Edited by JinjoVitis, 11 January 2014 - 01:54 PM.
  • 6,732 posts
Posted 11 January 2014 - 09:44 PM
I've attached a few documents to learn about the technology including  and heat and mass balances . This should be a good start for your work.
Evaporators are shell & tubes equipment .
http://www.nzifst.or...vaporation2.htm
hope this helps
#3 JinjoVitis
JinjoVitis
  • 5 posts
Posted 11 January 2014 - 11:26 PM
Thank you very much
#4 kenalizer
kenalizer
  • 7 posts
Posted 31 January 2014 - 10:17 AM
To simulate a multi effect evaporator in a simulation program such as Aspen HYSYS, is it a good idea to use a few flash separators and intercoolers for simulation purpose?
