Respected Seniors and Friends
I am a new in this forum . I am doing a master thesis on the Design of Water to Air heat Exchanger for Heating a Building or Room .My task is that I have to utilize the hot water whose intel temperature in a heat exchanger is Tin=80 C which has to exchange with air at an inlet Tempertaure T air =20C.Outlet tempearture of Air is Tair, out = 26 C which is for our requirement to heat a room. For this I have to calculate the no of tubes , heat transfer surface area and lenght of tube required . After getting my result I have to order it and install it practically for a heating system.
I have the follwoing queries which is given as :-
1.How I have to find these Calculation (no of tubes , length and surface area )
2.Is induced fan is suitable for this application .How I use fan calculation in LMTD or NTu Method.
3.I am very confused about Fin calculation .It seems to be difficult calculation. Should I inculde in it . How i can use it.
3.What should i take Air inlet vellcotiy and water inlet velocity.
It would be really appreciate if you please send me the Excel file calculation and realted any reference pdf books here.
Thanking you in anticipation
Awais
