Dears
I Want to know where is the best place for injecting the emulsifier?
in wellhead ,in manifold or before slug catcher or before desalter?
thanks
Posted 20 February 2014 - 05:02 AM
Dears
thanks
Posted 20 February 2014 - 05:25 AM
roshimessi,
Do you mean "Demuslifier" which breaks oil-water emulsions? Please clarify.
Posted 20 February 2014 - 04:27 PM
roshimessi,
Dear ankur
i think it is demulsifier , which is used for water and oil treatment.
I Want to know where is the best place for injecting the demulsifier?
Posted 26 February 2014 - 09:45 PM
You may need to do some tests to verify where the best place is to inject the demulsifier. However, the general rule is that the better mixing the better effect of the demulsifier. Therefore, you should inject the demulsifier as early as possible.
If you have a large quantity water needs to be separated, you should first separate the water and then inject the demulsifier to avoid wasting demulsifier because of the demulsifier cost.
Posted 27 March 2014 - 02:33 AM
All,
A very good article on oil demulsification is available at:
http://petrowiki.org...on#.UzPURaiSyIU
Ankur
Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
Water Injection SystemStarted by Guest_Frederick34_* , 08 Jan 2024 |
Washwater Injection To Hydrocarbon Stream At High Temperature And PresStarted by Guest_Venkat @89_* , 17 Sep 2023 |
