Level Transmitter Sizing Inputs
level transmitter dp level gwr calibration range probe diameter probe length
#1 mbilal83
mbilal83
  • 7 posts
Posted 26 February 2014 - 03:30 AM
Hello All !
I'm in the process of specifying Level Transmitter for a specific application.
I can select the required type of transmitter based on standard applications and limitations.
What I would like your help on is:
What are the necessary inputs/data/drawings required from process and mechanical for selecting:
1. Probe diameter for GWR
2. Total level & calibration range
3. Instrument range & CC distance for DP type level transmitter
#2 ColinR33
ColinR33
  • 106 posts
Posted 27 February 2014 - 06:38 PM
I'll try to help out:
1. Usually the GWR probe diameter is specified by the vendor.
2. Total level and calibration range should be set by the process engineer who knows the range of liquid levels he wants to see (he is the one who should be specifying levels on the vessel drawing).  For a single point level I usually use a minimum of 14" jig set on the transmitter.  Once you start adding in hi, hi-hi, lo, and lo-lo levels it is a simple matter of making sure you have enough range to cover them.  Eg:
HHLL : 48"
HLL: 42"
NLL: 30"
LLL: 16"
LLLL: 10"
Difference between HHLL and LLLL = 48-10 = 38".  Now you add 4-6" to either end of this to make sure you are not right at the end of the sensing limit, viola!  50" is your measuring range, and can also be the jig set (Center to Center dimension for level bridle nozzles)
3.  Much the same here, but for a dP type transmitter you also need the liquid density/S.G. so the liquid head can be converted into height.  Make sure that the liquid density is relatively constant for this application or you can get siginificant level errors as the liquid density changes from what the transmitter was calibrated to!
Hope that helps.
Cheers
