Diesel hydroteater unit, anyone has the information regarding tis topic pls drop me a msg. Thank you!
Request Information Of Diesel Hydrotreater Unit.
Started by Chowccl, Mar 24 2006 11:41 PM
7 replies to this topic
Posted 24 March 2006 - 11:41 PM
Posted 28 March 2006 - 09:40 AM
Have you googled for it yet? Even Wikipedia has an article on it.
Posted 29 March 2006 - 01:22 AM
QUOTE (joerd @ Mar 28 2006, 10:40 PM) <{POST_SNAPBACK}>
yes. i googled and i got wat it mean on wikipedia. But tat not wat i wan. I wan the flowsheet of how the diesel hydrotreatering. All of them are start from crude oil and end after disesel coming out, no continue mentioned tat how to hydrotreater the diesel.
thanks.
Posted 29 March 2006 - 10:05 AM
Ok, licensors are Shell Global Solutions, UOP, Haldor Topsoe, and others. One example of a flow scheme is http://www.uop.com/o...Unionfining.pdf
Most hydrotreaters are of the single stage variety, and look very similar, although each licensor has his own typical configuration.
#5 Guest_Profe_*
Posted 29 March 2006 - 03:16 PM
Posted 04 April 2006 - 12:29 PM
thanks a lot.
#7 Guest_Hamadi_*
Posted 10 April 2006 - 05:29 AM
Hi
In Ruwais Refinary LGO (Diesel) cut is drawn off from distillation column and enters the LGO hydrotreater unit. In this unit first the LGO is mixed with H2 (hydrogen) and after that it is heated by a fire heater type and enters the reactor. Many kinds of reaction happens inside this reactor, for example desulphurization, oxidation, nitrogenation,....etc.
After that the reactor effleuant goes to HP separator and then LP separator to Knock out H2 and recycling it again to the system with some H2 makeup gas.
Finally the flow goes to a stripper to strip away light hydrocarbons(C1,C2,C3,C4), H2S(the result of the reaction of mercaptain with H2) and other gases.
There will be a small amount of Naphtha or Kerosene may occur due to the reaction inside the reactor.
Posted 10 April 2006 - 08:40 AM
I don't suppose you recycle H2 from the LP (low pressure) separator. You may have 2 separators in the H2 recycle loop, a hot HP separator and a cold HP separator.
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , Today, 02:02 AM |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
