Once a heat exchanger is sized, then if for one of the stream if flow rate or inlet temperature varies then how to evaluate conditions at outlet. please help.
regards
rsk
Posted 25 March 2014 - 08:48 PM
regards
rsk
Posted 26 March 2014 - 02:53 AM
If inlet temperature and flowrate changed, check the velocity at the shell or tube side, pressure drop, new vs available heat transfer area, heat exchanged.
Royen
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , Today, 05:29 AM |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
