hi
I want to calculate amount of hydrogen required in NHT plz tell me what would be the procedure ?
Posted 06 April 2014 - 03:20 AM
hi
Posted 09 April 2014 - 10:19 PM
Hydrogen requirement in naphtha hydrotreating may include three aspects:
1, Chemical consumption for chemical reactions including sulphur, nitrogen removing, saturation reactions. If you know the naphtha composition, you should be able to calculate the hydrogen required for this part - very small part for naphtha hydrotreater.
2, hydrogen dissolved in naphtha.
3, To keep the hydrogen partial pressure, somewhat exhaust hydrogen will be released to flare and new hydrogen will be added to hydrogen recycle stream. This part hydrogen requirement is based on your unit pressure and product specification.
For hdyrotreating process, normally you specify the unit pressure, temperature, H2/oil (vol) ratio to keep the catalyst bed in a trickle bed range.
Posted 10 April 2014 - 02:20 AM
In addition to the points mentioned above by TS1979, take into account the olefins / unsaturated compounds present in the Naphtha feed, which will absorb hydrogen to be saturated.
So the % of cracked naphtha shall determine the amount of hydrogen required. Hope this helps.
Posted 23 April 2014 - 02:12 PM
thanks . I need any solved example do u have any ?
Srn HydrotreaterStarted by Guest_EngrHamza_* , 11 Jul 2023 |
Coke Formation On Hydrotreater Catalyst Vs Ccr In FeedStarted by Guest_Venkat @89_* , 16 Jan 2023 |
Ccr Reduction In Vaccum Gas Oil HydrotreaterStarted by Guest_Venkat @89_* , 16 Jan 2023 |
Conradson Carbon Residue Of Hydrotreater FeedStarted by Guest_Venkat @89_* , 16 Jan 2023 |
Diesel Hydrotreater System PressureStarted by Guest_Venkat @89_* , 08 Oct 2022 |
