I am using ProMax to model CO2 capture from syngas using MDEA (50 wt% + 3wt% PZ). I would like to capture 90% CO2.
I am having issues trying to limit the CO2 to 90% capture while keeping the CO2 loading (moles CO2 / moles of amine) in rich amine stream out of the absorber at 0.40. Inlet gas stream is free of H2S and has ~40 % CO2.
My simulation conditions are as follows:
Absorber with 7 ideal stages
Stripper with 10 ideal stages.
Feed inlet to absorber at 110 F, 650 psia
Lean amine into absorber at 120F
I do a LP flash followed by a heat exchange between the rich amine out of the absorber and the lean amine out of the stripper and rich amine enters the stripper at 190F. The condensor temperature is kept at 120F. The reboiler heat duty is set to ~0.50 lbs of 50 psig steam /gallon of amine circulation.
The amine circulation rate is set to provide 90% CO2 capture. With this setting, I get the acid loading for rich amine to be ~0.67. This appears to be too high and could lead to corrosion. So I tried setting the amine circulation rate to a value that will give acid loading in rich amine to 0.40, which doubles the amine flow-rate and also doubles the heat duty to the boiler and results in 99.95% CO2 capture.
Since the target is only 90% CO2 capture, a 99.5% CO2 capture seems to be an overkill. I feel there should be a more economical way to capture only 90% CO2 without the high acid loading for the rich amine flow. But I can't seem to figure out how to do that.
Also, with activated MDEA, what is a safe limit for acid gas loading ? I set the absorber for 650 psiq operation, and the stripper at 30 psia.
Any hints on what I can do here ?
I can provide more details and the PFD, if that will help.
Thanks for all your help.
