Hi all,
Need a quick advise from all the experts:
1) Our existing sonic flare tip is designed for 30 MMSCFD, however it is anticipated that the incoming production flowrate will increase beyond the design rate in one or two years time. What is the consequence if the continuous flaring rate exceeds 30 MMSCFD, ie. 40 MMSCFD? Backpressure for sonic flare tip should remain the same since it's sonic velocity.
My interpretation is : higher exit velocity will cause higher noise level and radiation. For the tip design, it will choke at 30 MMSCFD, but can it relief 40 MMSCFD gas?
2) How to determine rated capacity through an oversized PSV?
Based on the revised fluid composition, it is calculated that an L orifice is required for blocked discharge on separator. However the existing PSV installed is P orifice, which is 200% overdesigned. To keep the existing PSV, is it really necessary to check the inlet and outlet line loss based on the rated capacity through a P orifice, which is 200% higher than the actual relief flow? This is not practical given that the incoming flow is a lot less than the rated flow.
Appreciate for all the time and opinions.
