Has anyone used Annex D of the new API 2000. Annex D says the way to convert from STP to NTP and vice versa. Especially Eq D 37.
Thanks,
Vr
Posted 10 December 2014 - 11:58 AM
Thanks,
Vr
Posted 10 December 2014 - 07:11 PM
After going through a lot of previous posts in cheresources, my understanding is that Grahams law of Effusion is only when the two gases (Blanketing gas and Air) are at the same conditions.
We have to use
ACFH = SCFH * (Pstd/Pact)*(Tact/Tstd)*(Zact/Zstd)
for converting Blanket gas (Nm3/h) to Air (Nm3/h).
qair = x / Mair * Wfl * SQRT ( Mair * Ti / Tair * M).......D37
One person has used Annex D Eq 37 for converting am3/h of blanketing gas (80 C, 1 kPag) to Nm3/h of air. As the blanketing gas is Fuel gas with MW - 16.4, Density at tank operating conditions - 0.5 kg/m3, the volumetric flowrate calculated using the above Eq is very low.
If any of the experts can tell me if this is the right way of doing it, I would appreciate it.
![]() Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
![]() What Is The Difference Between Api 521 Sixth Edition & Seventh EdiStarted by Guest_Murtaza Lashkerwala_* , 13 May 2024 |
Api 2000Started by Guest_Lucianaa_* , 04 Jan 2024 |
![]() Le, Lemax "api 650 Annex F (Figure 2)"Started by Guest_KevinGTX1_* , 01 Aug 2022 |
Nitrogen, Api 2000 Section 3 Vs Annex FStarted by Guest_Rmm27_* , 23 May 2022 |
